cap on buzzer
cap on buzzer
cap on buzzer
I've got a simple control box for a gate arm, adn there's an alarm buzzer.  It's a 24v standard issue black, maybe 2" diameter 100dB or so buzzer.  Question is, why is there a 470mF cap across it?
RE: cap on buzzer
I'm not sure.  470mF is HUGE!!
Is it the size of a half gallon of milk?  If not please look closer and see if it is 470uF or .47uF or .047uF or 470pF.  These would make way more sense.
Keith Cress
RE: cap on buzzer
The capacitor is to reduce the amount of radio frequencies generated that interfere with radio and TV reception in the immediate area.  I assume this is an electrmechanical type.
RE: cap on buzzer
oops, sorry, yes, uF!  35v
so you think it's probly a filter?
RE: cap on buzzer
Not nF? A 470 uF capacitor doesn't work well as an EMI suppressor. It usually has too high an internal impedance at HF for that.
Gunnar Englund
www.gke.org
RE: cap on buzzer
I thnk it was used to bump up the voltage a little (it was on the output of a FW rectifier) tomake the buzzer louder.
RE: cap on buzzer
That is obvious - if you know about the full wave rectifier. A smoothing capacitor. And, yes, 470 uF would be a typical value.
Why did you ask if you knew the answer? Quiz departmant?
Gunnar Englund
www.gke.org
RE: cap on buzzer
that was a guess...I assumed the cap would charge up to the peak value of the lumpy dc and provide the buzzer with a little more power....
RE: cap on buzzer
Electromechanical buzzers produce a lot of low frequency EMI hash. In cars they can create problems with speakers and AM radios.
However, if the 'buzzer' is really a piezo-type, then a 470uF would cause it to beep a little longer when pulsed. A quick 'chirp' would turn into a very short beep.
