SORTING DRAWING SHEETS
Hello, I am working on a Catia assembly drawing. This drawing consist of approx 16 sheets (so far).
That is the easiest way to sort sheets?
What I want to do is re-arrange the order of the sheets (i.e. making sheet 4, now sheet 8 etc). Inserting a new sheet between existing sheets. Seems the new format ALWAYS goes to the back.
I know I can rename the drawing sheet in "properties", but how can I move the sheet so it's order is correct in the "TREE"?
Thanks much
Thanks much
RE: SORTING DRAWING SHEETS
What I have been doing lately is adding a new sheet, and copying data from one sheet to the next. In doing this though, sometimes I LOSE dimensions (not sure WHY).
HELP....
Thanks, again
you have sheet 1,2,3,4
press CTRL and select sheet 3,1,2,4, then CUT (CTRL + X)
then past... (this work with R16)
you really should consider upgrading to R16 or 17...or people will think you're not using a legit catia license and won't help you anymore ;)
This company, DOES NOT want to upgrade....I won't go into details why....but, what can we do.
Makes it worse we have NO help files, gee I wonder why.
Thanks again.
Unfortuately two sheets I LOST 50% of my dimensions, not sure why Catia does this.....
Lucky I tried it on a copy file.
Thanks Again
