HP to wheel size conversion
I am trying to turn a generator which requires 30hp to turn at 500rpm. What amount of Force or Torque (I am not sure what the best measurement would be) would I need to apply to a 2 inch shaft to achieve this?
The shaft will be attached to a 2 ft diamter steel wheel pulley.
Thanks for any help-
820currie
820currie
RE: HP to wheel size conversion
The answer to your question is:-
power= 2*pi*N*T/60
were power = 30hp*746watts
pi=3.142
N=rpm
T=torque (Newton metres)
rearranging the formula we get:-
T= power*60/(2*pi*500) T= 427.426 Nm = 3773.822lbin
if your applying your torque to the 2FT pulley
then the force you need to exert
is 3773.822lbin/12in" = 314.5lbf
regards desertfox
Thanks a bunch for the help.
Sanity question. It sounds like 315 lbf is pretty extreme. Should I get a bigger pully or something to help reduce the amount of force required? Would that help? Is there a formula to use to help reduce the amount of force required to turn this object?
Thanks for your help.
820currie
You can reduce the force req by increasing the pulley radius.
torque= force * radius.
However if you change the pulley size you will have to also change the pulley size with which you drive it with.
regards desertfox
