Bonding to powder-coat
Hello, All:
Could anyone suggest a type or specific adhesive for bonding to a polyester based powder-coat?  The adhesive would obvioulsy be applied after coating, but it must withstand intermittent exposure to 300 degrees F.  It would be most beneficial if the set-up time was 1 ~ 2 minutes or less and no heat cure was required.  The other substrate is a ceramic product.  I have found some products wich work, but corruption of the powder-coat is a concern and I have not completed the aging testing.
Thank you for your help.
Mac
