Weld Thickness
Weld Thickness
Weld Thickness
Ron,
If you had to install 6- W8by31(8"by8")wide flange beams 7'long to side supports of 1/2 steel, running consecutively 3'apart with a load of 50,000lbs on them. How would you calculate this? How much weld should go into welding these flanges?
Jim
