Exporting Dimensions issue?
I have created a macro that exporting selected dimensions from a drawing and places the dimensions in a access database table. The issue is when i open the said table the dimensions that populated the table are incorrect but not by much.
for instance if the dimension i export is .375 the dimension that is exported is .37499991256
Any help would be appreciated.
thanks
RE: Exporting Dimensions issue?
Are you sure the exported dimensions are whole, and not being rounded by the accuracy settings in SW?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
i have ran this macro before the only difference was i was exporting to an excell sheet.
where do i change the accuracy settings?
You can't adjust the actual modeling accuracy, only the display settings.  If the part was modeled at .37499991256, that is what will be exported.  If the model was created at .37500000000, that should be what exports.
You were correct.
The model i was using to check the design was not accurate.
thanks
