COMMERCIAL GRADE CASTINGS.
Does anybody know the definition of "COMMERCIAL GRADE CASTINGS" ?
Are there different grades of "Commercial Grade" castings ? If "YES" , would you please give me a brief explanation on that ?
Thank you.
Thank you.
RE: COMMERCIAL GRADE CASTINGS.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
These will be supplied without any test certificates, probably do not get machined or have limited machining(drilled holes) are not used under low or high temperature environment. No NDT is specified,bulk of the steel castings I produce fall into this category.We earn better margins in these rather than in WCB grades where testing and documentation takes the steam out .
