Measure of cross sectional area along a line (ProE wildfire 3.0.)
Hey!
I have a pipe-like mould with a 90 degree bend, made as one protrusion.
Its solid, and I want to meassure its cross sectional area at several locations, along a line that I define. (alternatively, just pependicular to the outer surface)
I want to make a chart: distance from the end vs. cross sectional area.
Hope you can give some advise!
Best regards
Sigurd
Best regards
Sigurd
RE: Measure of cross sectional area along a line (ProE wildfire 3.0.)
Create a curve which will represent the centerline. Add points on this curve (offset from one end). Add planes thru his points.
Then in Analysis Feature create the cross sectional area and choose "yes" when system asks for creating the xsec_area parameter. Repeat for each point.
All you have to do then is to add relations you can use in your drawing table:
area1=xsec_area:fid_analysis1
area2=xsec_area:fid_analysis2
area3=xsec_area:fid_analysis3
In drawing mode just type &area1, &area2... and you'll get the parametric area of the sections and &d1, &d2... for the linear points dimensions.
Good luck
-Hora
