Splined Stainless Steel Stock
I'm looking for a supplier of stainless splined shaft stock (approximately 3 inch diameter x 5 feet). I need to make a friction roll.
I found this supplier. They can roll a standard stock item for me but I have to buy a minimum of 10 feet at $194/ft.
http://www.grobinc.com/coldrolled/cust_tubing.htm
Does anyone else know of a supplier in the USA?
RE: Splined Stainless Steel Stock
Involute or strait?
It doesn't matter about the dp or the tooth form. I'm just using the splines for a friction roll.
http ://www.ang elfire.com /planet/ga dgetforum/ index.html
