Need help becoming a MWD
Hey all,
Are there any books out their I can use to help me fully understand every aspect of becoming a MWD / DD
RE: Need help becoming a MWD
What is "MWD / DD" ?
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
It's either a dyslexic weapons of mass destruction wish or Measurement Whilst Drilling. If the latter, I think Schlumberger are one of the main players in this field. As far as books etc on the subject, there is a link from the Schlumberger site quoting a list of references:
http://www.glossary.oilfield.slb.com/maincredits.cfm
MWD= Measurement while drilling,
DD= Directional drilling/ driller
MWD provide data while the oil well bore hole is being drilled such as direction the drill bit is going as well as depth, pressure, etc. Measurements are done by instruments that are part of the drill string, hence the term, Measurement While Drilling (MWD)
A directional driller works with the rig's driller to ensure that the well is drilled in the correct direction to hit the oil and/or gas payzones in the earth's formation.
Both who works in the oil field exploration and production (E&P). As to understand all aspects of the work, there is non better than joining an oil and gas service company and getting the hands on experience.
Most DD's come from a MWD background.
Sperry Sun/ Halliburton is one such company. Another will be Baker Hughes' Inteq.
Checkout Rigzone.com, there you can search for other service companies, as well as books that deal with MWD and DD.
Good luck
Hey thanks for the info, I went to the link your provided, their was alot of information I will use.  Thanks Mammut74 also for the info, Rigzone.com is now my home page.
PS. please read the tip section by Borg I posted it under tips, but really needed it in the question section.
Please help a newbee :)
