diameter ratio for hollow shaft
hello
In reading various design specs for hollow shafts (that will see torsion and rotating bending), I have come across the design guideline that ID / OD <= 0.65.
In fact I have several Navy specs that say "ID / OD must = .65" .
Going through my books, I cannot find a rationale for this.
Any guidance as to where this comes from would be appreciated.
thanks
magicme
thanks
magicme
not all that glitters is gold.
RE: diameter ratio for hollow shaft
Common sense tells me that the ratio is based on the notion that the outer diameter of a rotation shaft carries a larger portion of the torsional load while it decreases to nothing at the center of the shaft.
So, short of working a spread sheet out to determine the answer my best guess is that the .65 results from some value that states "that 80% of the load" is carried in that id/od range.
roadapple
<tg>
I recall years ago when working with press-fit shaft couplngs, the same .65 diameter ratio was used for the coupling hubs.
regards
magicme
Cheers
Greg Locock
I haven't found a definitive source for the 0.65 however
"The Mechanical Engineers Data Handbook" by James Carvill I
have found that Di/Do = k and on page 7 of this book. It lists various k values for hollow shafts and compares the
outer diameters, weight and angular deflection for a particular hollow shaft against that of a solid one ie:-
k 0.5 0.6 0.7
Do/Ds 1.02 1.047 1.095
Wh/Ws 0.783 0.702 0.613
Θh/Θs 0.979 0.955 0.913
the fomula's given are as follows:-
For a hollow shaft to have the same strength as an equivalent solid shaft:-
Do/Ds = (1/(1-k^4))^0.3
Wh/Ws = 1-k^2/((1-k^4))^0.3
Θh/Θs = ((1-k^4))^0.3
and finally k= Di/Do as previous
hope this helps
best regards
desertfox
but I tried ratios of that tabulated data and can't find a reason to pick one value of k over another.
still hunting,
and of course the longer it takes, the more determined I am to find the rationale!
magicme
"not all that glitters is gold"
The only reason I can see to pick different values of "k" would be suit your particular critera ie:-
if weight was the main critera then you would perphaps use
a hollow shaft with a k=0.7 as this would only have 61.3%
of the weight of a solid shaft.
If you were restricted for space you might choose a k=0.5
to keep the diameters of a solid and hollow shaft fairly close.
regards
desertfox
I find this equation interesting.
If we let the ID equal OD - 2t, then t=.175 OD
ie the wall thickness. I do not know where thin
section vs thick section columns is defined.
If so then the equation
ID / OD <= 0.65.
may make some sense.
Or t >= .175 OD
