creating DXF / DWG from V5 going to V4, settings, need help
Hi gang, I have a problem (again). I have to create a drawing in CATIA v4. The drawing format(s) is / are in V5 (release 14) - I am using the Ford enviroment setting if this makes a difference. I have created DXF and DWG from V5 drawing format symatically changing setting on V5 using the V4 CATUTIL and these are the results of V4, I get only wire frame - no text most of the time. If I select "graphic" in the DXF tab under V5, the results in V4 are lines and arc to simulate text. I need to be able to edit the text (in the title blocks and the Standard notes, which are lots of. Could anyone give me the settings for V5 and or V4 setting so I can translate this V5 to V4. I have a quote package to get out and I'm under pressure. any help will be great - thanks in Advance - Texaspete
