'Solidworks Help Topics' option
Here's a problem I'm having and it's probably so obviuos that I don't see it: I upgraded successfully to SW 2007 and it runs great. The minor problem I'm having is that I don't have the 'Solidworks Help Topics' option. I accessed the 'customize menu' option and picked the 'Solidworks Help Topics' option but no luck. The odd thing is that I do have the option when I don't have anything loaded up in the Solidworks screen. I tip would be much appreciated.
RE: 'Solidworks Help Topics' option
If you have subscription, download "SolidWorks Help File".
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Thanks ctopher. But I'm still baffled as to why I do have the option when I don't have anything loaded up in the Solidworks screen. BTW: SW portal for downloads is down according to the website until today?
Thanks again.
Not sure why it would not show. It shows on mine.
The SW portal has been working for me today.
Chris
AutoCAD 06
What does your VAR have to say about the problem?
Did you disable all Anti-Virus programs before installing?
Whether you did or not, try:
Alternative to try before reinstalling  FAQ559-507
How do I Repair or Modify of a SW Installation?  FAQ559-908
How do I do a clean uninstall & reinstall of Solidworks?  FAQ559-488
cheers
Hey CorBlimeyLimey.
Thanks for your response. I did get in contact with our VAR; they will get back to us shortly. Before I upgraded I had done everything on the threads you refer to plus disabling the anti-virus.
Thanks again.
FYI: I applied service pack 2.2 and the help file appeared. Thanks to all for your help.
