Macro for updating error
Hello:
I have a problem with tooling:Along the updating proccess of the  tooling, I have a curve, paralell from an other one that some times can be in error.In these cases the curve must be deactivated.
I tryed knowledge advisor Reactions, "when update happens something(parameter) changes, but I cant do anything when update error happens because the reaction does not run.
¿Someone knows what can I do?
Thank you very much.
As an example you can do a circle in a sketcher, an a paralell curve(wireframe) from the sketcher to the inner side. If you put an offset value for the paralel bigger than the radious of the curve you will have an update error.
thanks again.
