Sheet Metal
Sheet Metal
A sheet metal part created with the Flatten Bend/Process Bend method. What exactly does the radius setting in the (Process Bends) control...?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Sheet Metal
Usually, the bend radius should be set to the desired radius of the sheet metal bends, and should correlate to the available tooling for sheet metal forming.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Sheet Metal
bends, just letting the settings propogate thru from what I set in the sheet metal1 params. Changing the settings in process bends doesn't seem to have an effect on the flat pattern. Just curious.
RE: Sheet Metal
http://www.sheetmetaldesign.com/index.htm
http://www.sheetmetalguy.com/index.htm
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
