Variable Pitch Helix
I'm having difficulty creating a variable pitch spring where several sections of the spring have a close wound pitch (i.e. pitch = wire diameter = .003"). SW yells at me and says I have to choose a value greater than .00393701. Anyone know if this is possible?
Tim
Tim
RE: Variable Pitch Helix
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
The end result is rather hack and can be horrible for FEA, but it is a way to communicate your intention.
Christopher Zona - Product Designer
Concord, Ontario
"pitch=wire diameter-0.003"
make the wire size 0.0029999" and the pitch 0.003".
If you set your dimensions to only display 3 decimal places it will round to 0.003 and the model will work.
