Command line controls everything ...
Hi everyone,
I don't know what I did to get where I am.
The command line controls everything. Example : I want to save, i do File/SaveAs/, I have no dialog box that pop-ups, only the command line that asks me for the path ...
I want to open a new layout from a template --- same thing, no dialog box, only the command line.
Does anyone know how I could get back my dialog boxes ?
RE: Command line controls everything ...
Try setting filedia=1
____________________
Acad2006, Terramodel
From AutoCAD Help:
Quote:
These system variables also affect the display of dialog boxes:
ATTDIA controls whether INSERT uses a dialog box for attribute value entry.
CMDNAMES displays the name (in English) of the currently active command and transparent command.
EXPERT controls whether certain warning dialog boxes are displayed.
FILEDIA controls the display of dialog boxes used with commands that read and write files. For example, if FILEDIA is set to 1, SAVEAS displays the Save Drawing As dialog box. If FILEDIA is set to 0, SAVEAS displays prompts on the command line. The procedures in this documentation assume that FILEDIA is set to 1. Even when FILEDIA is set to 0, you can display a file dialog box by entering a tilde (~) at the first prompt.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
