Magneto-Rheological shocks
What is everyone's opinion of the Magneto-Rheological shocks? They have been described as the technology of the future for 20 years. Now that they are entering production do they have some potential of becoming popular? In addition to GM's current applications like the Corvette Ferrari is putting it into one of their next cars.
Does anyone besides Delphi and Magneshocks make them yet? Does any one have experience with each company and their products?
http://www.magneshocks.com/
http://del phi.com/ma nufacturer s/auto/chs teer/ride/ magneride/
http://www.lord.com/tabid/3329/Default.aspx
TIA
http://del
TIA
RE: Magneto-Rheological shocks
http://www.zf.com/defaultz.asp?lang=1&id=4841
It may develop into a sizable market, but not quickly, and it will continue to have competition.
Cory
I have heard of accelerated wear in areas of focused fluid flow, at least in off-road applications.
It sounds like a great idea and could be really good dependent on my question above.
Cheers
Greg Locock
The MR fluid reacts fast but not fast enough for true high speed wheel control. They advertise 1 ms switching time but it is really more like 17-18 ms to switch from a low force to a high force (say 1000lb change). It takes the magnetic coil 2 ms just to get the current change. I am near certain (obviously I don't work for Delphi) that they are only used to control sprung mass motions. If it could be faster then I think it's superior to its competition.
I worked for another supplier which developed an electro-mechanical adaptive damping shock and one very nice thing about the MR damper is that there is no mechnical valve. A semi-active damper must be able to change "on force" meaning that when the damper is under a large rebound velocity it must switch from a low to a high rebound force. Thus a mechanical valve must overcome the high pressure differential across it to move into a "stiffer" position. Pretty difficult to acheieve. If your damper cannot do this then it must wait for a drop in velocity before the valve position can change. If you expect an active damper to control the unsprung mass motion you must be able to switch "on force".
I think Fabrico reffered to this, but the MR damper only causes a local viscosity change about the piston. Fluid far from the piston is unaffected (or less affected I suppose). This makes it more difficult to get a reasonable spread in damper forces (large max with a reasonable low force).
It seems like heavy vehicle applications are also one of it's strengths. Given the issues with weight and cost that makes sense.
It is supposed to control both sprung and unsprung masses but I don't know how well.
The response speed and electronic connection might put MR toward the front of the line for active suspension, if and when it ever really gets here. One of the cross-town rivals is an electrically powered linear actuator.
Good point on the failsafe, that is definitely true. I never used the Delphi controller supplies for the MRs, but I would be very surprised if Delphi were able to get unsprung mass control based on use with another controller we used (maybe you know better?). They are slightly faster than any other system we benchmarked but achieving ~ 15 ms response time on a dyno is different than acheiving on a car driving on a pot-holed road.
There is another company I saw a presentation for with essentially a hydraulic ram and a mood valve, claiming that it achieves 1 ms switching time with a huge force spread.
Cheers
Greg Locock
Are you talking about the Bose system?
I can't remember where now...but there is also someone working on a semi-mechanical friction system. If controllable, a friction system could be faster and simpler, at least at certain things. Similar to their oiled counterparts, the friction can be introduced separetly at low or high amplitudes or frequencies. It can also be combined with other methods. All current damping systems work with friction of some sort.
Truley active suspensions may not use any form of friction because they may no longer control things through the asorption of energy. The best suspensions on earth have no damping.
