Sandwich, epoxy
Sandwich, epoxy
Which are most commonly used standards for mechanical testing of the subject?
BR
Ulf
BR
Ulf
RE: Sandwich, epoxy
Can you be a little more explicit.
Do you want to test the resin, or do you want to test a layup using a particular core or resin system.
B.E.
RE: Sandwich, epoxy
ASTM C297 - Tensile strength of flat sandwich construction in flatwise plane,
ASTM C393 - Flexure test of flat sandwich construction,
ASTM D635 - Burning,
ASTM D1781 - Climbinmg drum peel test for adhesion,
ASTM D3418 - Glass transition by DSC + ASTM E1356 - Assignment of Tg, or ASTM E1545 - Tg by TMA
RE: Sandwich, epoxy
epoxy resin + glass fibres on both sides of core material.
BR
Ulf
RE: Sandwich, epoxy
It looks though Avior has most of the useful tests nailed.
You might also try ASTM C273. Shear properties of sandwich core materials.
B.E.
