need to know if these compounds can be used for a hull
can you use a treated carbon fiber for a hull of a submarine it seems feasible and lifht weight im just unsure about its integrity to withstand pressure plus it would be extremly light weight
_____________________________________________________________
the real heros are the ones unnamed and unknown and that only exist in the shadows
RE: need to know if these compounds can be used for a hull
Light weight would be a virtue in a flooded sub, like divers use, where it would allow budgeting weight and strength for other things.
Light weight is not a virtue in a non- flooded sub, where you typically have to add ballast to offset the natural buoyancy of the hull.
Mike Halloran
Pembroke Pines, FL, USA
I'm not aware that you could improve it by heat treating it, since it's already been heated. Some, at least, is made by roasting rayon fiber.
Graphite is a form of carbon. You could coat the carbon fiber with graphite, I guess. That would make it slippery, which in a composite, is A Very Bad Thing.
You need to do some reading. First, you need to understand the difference between 'carbon fiber' and 'carbon fiber composite'. You are clearly confusing the two.
I know carbon fiber composite is all the rage these days in real race cars, where it has some virtues that offset its cost. But it's not magic. It's really just a bit stiffer and stronger than glass fiber composite, so it can be made a bit thinner and therefore lighter.
I'm suspicious that a lot of faux carbon fiber composite is also being sold for faux race cars, but that's another discussion.
Now, as for making a submarine hull out of carbon fiber _composite_, yes, it's possible. It may not be the best material for the job. It's certainly not the cheapest.
Before you get too much farther, you need to get a price for a couple miles of carbon fiber tape.
Mike Halloran
I may be able to find a more specific ASME reference for you, but for a number of reasons I don't think I can provide any hints as regards a design collapse depth, so you're on your own there.
Norm
you know were i can get a copy of the asme codes free like an ebook or pdf that would be mutch appreciated if you could
thanks for the help
