Semi Technical question regarding shim stack size and their effect on
In most mass produced performance dampers today we see mostly progressively valve dampening curves it is to my assumption that this is due to the size (diameter and thickness) of the shim and the orientation of the shim stacks
Pic of progressive shime stack
http:// www.valvin gdatabase. com/hotlin e/valveInf o/images/s him_03.jpg
I know this is a general question but I am looking in to revalveing my old dampers
by only changing the shim sizes with in the stack.
I have always wondered by only changing shims (not gas pressure, oil pressure, oriface, preload on the stack, or piston size) how would you improve low piston speed force but keep the same high piston speed force
would a thicker shim at the base of the stack yeild higher low piston speed forces?
any suggestions on changing the above shim stack to improve low piston speed dampening?
http://
RE: Semi Technical question regarding shim stack size and their effect on
MB
