Push pull surface fills
Im having trouble making push pull points on surface fills can anyone help?
RE: Push pull surface fills
If you list the steps you are trying, maybe we can see what you are missing or doing wrong.
cheers
Try untrimming your fill surface. Freeform only works on untrimmed surfaces.
What command are you trying to incur?
Are you placing the Curves first?
cheers
What you could do, is transform the model in a solid (not a surface model), and use the free form.
