Swept Cut in an assembly
Hello all,
First time posting here. I've got an assembly that I need to make a profiled cut on a flat surface (think of using a mill to cut a pattern no a surface). I need to include a radius at the bottom of this cut. Problem is, 'Swept Cut' is not available when you're in an assembly. Mind you, I'm not trying to add any material to the assembly, just trying to add a radius to the profile of the cut.
I did a search for 'Swept Cut' in assemblies, and found this closed thread: thread559-107328 (from a while back), but no real solution.
Any suggestions?
Thanks in advance!!!
Any suggestions?
RE: Swept Cut in an assembly
Be careful though, if you create the assembly sketch with relations to parts, but then edit the parts and cut places you used for the relations, you have essentially created circular refs.
RFUS
-b
This is essecially like performing a boolean subtract in assembly mode but without consuming the body it referenced, so just hide the sweep when your through.
{o,o}
|)__)
"que?"
Work: Dell Precision 380-PENTIUM D 840 -PNY QUADRO FX3450 Drivers 77.56-2GB RAM--SW2007 SP1-RHINO 3.0 SP5
Play: Intel X6800 Core 2 Extreme - Asus P5W64 WS Pro i975X -2GB Corsair XMS-EVGA NV7900GTO(Mod. GTX Bios , FW93.71)-74GB Raptor-250GB WD Caviar
We came to the same conclusion as CorBlimeyLimey: used a series of Extrude-Cuts & Revolve-Cuts. Ended up creating five features (1 Plane & 4 Cuts) to get the job done.
