latent heat values
latent heat values
Anyone know where a good source online would be for latent heat values of various materials, namely oils?
RE: latent heat values
Try this:
http://w
I wouldn't trust 100%, but it has been useful for me.
Best regards,
JuanMC
Looks like a good sheet thought...are you familiar with how it works? Can you add fluids knowing the fluid properties?
THANKS!
About the density, I just took the specific gravity and multiply it by the water density.
Also, to add a fluid you can add (or replace) properties in the first sheet: API grav, and viscosity at 104°F and 212°F (you can easily find those). Maybe the density is related to petroleum standars.
I hope it could help you.
JuanMC
