Antiwear ZDDP
Antiwear ZDDP
I am trying to find out more information on a antiwear product ZDDP.
RE: Antiwear ZDDP
May be able to locate similar product
RE: Antiwear ZDDP
RE: Antiwear ZDDP
ZDDP is a widely used additive. It is zinc dialkyl (or diaryl) dithiphosphate which has anti-wear, antioxidant and corrosion-preventing properties.
This and other dialkyl dithiophosphates are prepared by reacting PS5 with an alcohol to form the intermediate dialkyl dithiophosphoric acid, which is then neutralised by a metal oxide (zinc's or otherwise).
The properties of the product depend on the metal atom and the alkyl group.
RE: Antiwear ZDDP
The empirical formula of the pentasulfide should be P2S5.
RE: Antiwear ZDDP
RE: Antiwear ZDDP
RE: Antiwear ZDDP
Concerning their chemistry, hydraulic fluids can be divided into four classes (i)mineral oil based, (ii)synthetic lubes, (iii)emulsions, and (iv)water-based fluids.
Organophosphorus compounds, and among them the multi-functional ZDDP is used in formulations of motor oils and anti-wear hydraulic lubricants. The response pattern of the ZDDPs is strongly influenced by the degree of raffination of the base stock.
There are ZDDP-free ashless additives, and those with ZDDP containing calcium detergents for improved thermal and hydrolytic stability of the ZDDP. Environmental regulations may bring about a change to ashless technology. Hydraulic fluids designed for the food and pharmaceutical industries require products that comply with specific regulations.
Overall high performance fluids contain 0.9-1.2% additives.
Formulations are known to contain up to seven additives depending on performance requirements. For example, when extremely low sludge figures are required, the use of dispersant VI-improvers may be considered.
If the ZDDP is Zn di-2-ethylhexyldithiophosphate, aminic or phenolic antioxidants are added to boost the oxidation stability.
