Winding Resistance Fractional HP Motor
We had an issue back tracing some wires through a terminal strip. There are 4 - single phase 110Vac 2 pole motors, each hot wire connected to an individual terminal.
Neutral/Common are all connected on a busbar.
What occurred when i did some continuity tests with a multimeter, was if i put 1 lead on the hot wire of 1 motor, i would get continuity through the other 3 hot wires BUT not through the neutrals.
Kind of thrown off by this.
I thought that with a continuity test, if the resistance is too high (which through windings of a motor lead me to believe that) i shouldnt be able to have continuity through all 4 motors.
Any ideas?
Paul
Any ideas?
Paul
RE: Winding Resistance Fractional HP Motor
Or is it the fact that you don't have continuity from winding to neutral that you find confusing? That is also perfectly normal - there is no connection to neutral in a three-phase motor.
Gunnar Englund
www.gke.org
Please clarify.
4 single phase motors. Two terminal leads per motor?
Connected to different phases of a 3-phase system?
I assume the motors are off line when the continuity test is performed, is it? but one terminal (to neutral) is still tied to the other 3 common leads?
This is a 110 Vac single phase 60 hertz Canadian.
1 hot wire (black) 1 neutral wire (white) and 1 ground wire (green).
(For the UK and Europe, it would be 220/230/240 single phase) which is 1 hot wire (brown), 1 common (baby blue), 1 ground or pe (green with yellow)
We have the motors each on there own switch.
All switches are off.
There is no power applied to any motors.
Yes 1 terminal is tied to the other 3 common leads.
Paul
BK
respectfully
JRaef.com
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." Scott Adams
For the best use of Eng-Tips, please click here -> FAQ731-376
