Metric units
Metric units
Metric units
I have a german catalog listing steel shapes and properties. There is a column with a heading "moment WX/cm3". What does this column mean?
How can it be used to select a beam designed from the determination of "I" and "S" in American units?
RE: Metric units
I'll venture a guess.  Since the units seem to be cm^3 I would guess that Wx is the section modulus (our "S"). This implies that W is the second moment of inertia (our "I") and x is the distance from the neutral axis.  Does the magnitude of the numbers in the column seem about right?
1 inch = 2.54 cm
Hopefully you can get a definitive answer.
RE: Metric units
section modulus is I/x, but the units are right ...
RE: Metric units
Wx is the equivalent of Sx - W stands for "Widerstandsmoment".
Moment of Inertia is usually denoted either Ix or Jx in German.
1000 cm3 = 61 in3
Gregor Wollmann
RE: Metric units
Downlad the program " convert.exe"  from this site:
http://www.rcmodelbouw.nl/download.html
it works well in converting the old units to SI units and back
Wollman is right with his translation of W.
