relation btwn inlet pressure and gas flow rate
Hello everybody,
I have a rotating flow. Gas (8at room temperature) is entering through some tangential slots inside the drum, and the drum is static.
Will the inlet pressure be a linear function or a quadratic function to the gas flow rate ?
Many thanks in advance
Best regards,
Abhishek
