"DISPSILH" in 2006
"DISPSILH" in 2006
"DISPSILH" in 2006
In AutoCAD 2000 DISPSILH=1 used to remove the display lines on a cylinder. This does not seem to be the case in 2006, the lines are remove when plotting but not in display any ideas. Thank You
RE: "DISPSILH" in 2006
Thanks Borgunit, not too bothered about plotting I just want the display to be smooth and without facets, clients often sit over me whilst I'm modelling and it spoils the effect!!
Is the cylinder a solid rather than a surface?
Did you also use the "hide" command?
