Is this a specialty bolt?
I am not having any luck finding a 9/16 clevis bolt with a 3-11/16 grip.  I have looked on the internet and could not find a table showing an AN29-?.  All of the suppliers that have tables listing clevis bolts seem to drop off at around 1/2” diameter.  Is there a specification that lists all of the AN hardware dimensions that can be downloaded for free.  I need this information for a personal aircraft and being that my area of engineering practice has nothing to do with aircrafts, buying a spec to lookup one bolt seems like overkill.  This particular bolt comes from a classic aircraft where there is no longer a manufacturer to provide support.  If this is a standard AN bolt, does anyone have a recommendation where to purchase 8 EA of these?
RE: Is this a specialty bolt?
CRG (Mechanical)
Can you use an NAS close tolerance bolt instead?
Or do you have to have the round head on the bolt?
B.E.
This bolt is available. Try http://www.usmilitaryfasteners.com/an/an21-36.htm
Your clevis bolt is AN29-66, 4130 alloy steel, cadplated.  You might be able to find the right size clevis pin or shoulder bolt (.560")to replace this.  I belive the minimum buy is 13 bolts ($100).
Cheers
AN29-66; NEW STOCK
Pacific Hi-Temp Hardware
4140 Van Owen Place
Burbank,   CALIFORNIA   91505
Phone: 818-841-0070 Fax: 818-842-7029
Email: pht@inreach.com Web Address: http://www.pacifichitemp.com
Minimum order of $35.00 VISA/MC/AMEX ACCEPTED
