Utility Trench repair
One of my clients has asked for a detail that shows trench repair with concrete reinforced with #10 mesh with 6"x6" openings tied into the existing concrete by dowels. Any thoughts or sources on this?
RE: Utility Trench repair
For pavement reinforced with WWF they don't dowel the new into the old. The detail calls for using the same size mesh and cutting a dovetail in the existing base. The patch width is the full width of the traffic lane; in the opposite direction it is the trench width + 1'-6" each side of the trench (W+3' total).
Similar for unreinforced pavement or asphalt pavement except the W+3 is reduced to W+2'.
Patch thickness for concrete pavement is the same thickness as the existing; for asphalt pavement it is 6" of asphalt on 6" of stone.
Here's a link to the two drawings. They're not the best quality but I think you'll be able to make out the important items.
http://putstuff.putfile.com/35353/8905346
Daniel Toon
