visual rep. of threads in a .idw???
When displaying a view in a drawing the threaded holes appear to be just thru holes.  ie. two dashed lines instead of one in a profile, or one circle instead of a circle and a dashed circle when looking the hole dead on.
Whats up with that??  anyway to change it?
Or how do I manually draw the 2nd hole/lines?
RE: visual rep. of threads in a .idw???
Sceep
 I'm on V11 and one way to fix this is to dbl click on the view and check the thread feature located on the display options tab.
Mark
THANK YOU DeSim!!!
thats exatly what i needed.
