Guardrails on drive and walks
IBC requires guardrails on ramps if adjacent to a 30" fall. IRC requires guardrails on porches and balconies. Is there any code or standard that requires guardrails for a residential driveway adjacent to a hypothetical 100 ft drop?
This seems to be a gray area in the IRC. Any thoughts?
(And beware of searching the forums for "guardrails" as I just spent 20 minutes looking through Star Wars links.....)
RE: Guardrails on drive and walks
htt
For a residential driveway, assuming it's for a privately-owned home, there might not be any standard other than prudence.
A driveway is certainly a walking surface from the means of egress to the public way in many cases and you can interpret this as requiring a guard. You can check with the local building official to confirm they will be required and if now, you may want to recommend this to your client.
Don Phillips
http://worthingtonengineering.com
I think it is an area that the code needs to address. We can say it is logical or a good thing to do and all that, but if it is not in the code it doesn't get done. In posing the 100' hypothetical to the local inspector, he said that it would be left up to the builder as there is nothing in the code requiring a guard.
And for this particular case, I am coming in after the fact to answer the question "was a guardrail required?".
ZCP
www.phoenix-engineer.com
Dik
