changing defaults for dimension style in dft
I'm trying to make a default template for my company which looks nice. My university has a template which makes all of the dimensions have larger text and other such adjustments which are nice, but this is in an educational file, so i can't just change the logos on it. how do I change the size of text/arrows/lines for every type of dimension (ISO, ANSI, ANSImm) or do i have to change it for each one individually?
thanks
thanks
RE: changing defaults for dimension style in dft
because one is an academic version and the other is a normal one
you could not copy them (the fulle version can't open the academic
files.
So you have to change them style by style.
Get into Format
--> Style
- select Dimension from the pull-Down
- select the style
click modify
when finished click OK
- proceed with the next style
finally click Close
Do not forget to save the template
dy
