I want to get more knowledge about PLC
I learnt PLC at Goverment Technological College Yangon. Now I got Bachelor Degree. I want to learn more about PLC.I want to know how can I do for my knowledge.
Thank for all
Thank for all
RE: I want to get more knowledge about PLC
Check out FAQ791-640
How much do YOU owe?
http://www.brillig.com/debt_clock/
I have an open source PLC design site (i.e. Free).
It uses the PIC microcontrollers for use. It requires
a PERL (free) interpreter to run. It takes another
open source project which has the gui interface for the
ladder logic, then you run it through this large perl
script that I've developed, which outputs pretty readable
PIC assembler code. You then run the assembler code through
the standard microchip tools and you can simulate the
operation using their MPLAB simulator (it's also free)
and, more importantly, you can actually program a PIC
microcontroller and have the real PLC to play with.
The whole toolchain is either open source (free) or
commercial (free) software. The only cost is for a
programmer for the PIC microcontroller and a couple of
dollars for the PIC microcontroller itself.
It's at the "alpha" to "beta" stage of development.
You can review it at it's temporary home at:
http://getok.net/plc2pic
if you are interested.
Cheers,
Rich S.
http://forums.mrplc.com/index.php?download=156
TW Controls - http://www.twcontrols.com
If you want to know what products are out there, download the product catalogs from Allen-Bradley, Siemens, B&R Automation, and maybe Danaher but they mainly are for motors. Trio is also big for the simpler motion projects. When you know what is out there you pretty much know what they can do.
If you want to learn to program them, you simply have to know Structured Text or ANSI C then each brand will have a set of libraries to do things like PID control or Trending. HMI construction will be similar to Visual Studio. You can learn ladder if you want, but it's a waste of time. No major brand makes a product that will only run on ladder and ladder is just to simplistic to do a real project.
h
click on Basics to PLCs and run through it online or simply download the booklet.
It's, as the name implies, basic but gets you started.
Wgn
