Extrude to surface with draft issue.
Hi all.
I'm trying to create 4 small bosses that terminate on a lofted solid. I created the first two on the bottom side with no problems but when I try to create the same ones on the top side SW tells me that the surface cannot be used to terminate the profile.
The bosses have a 10 degree external draft and if I lower this value to below 3 it will work. Or if I move the bosses closer to the center as I have in this image then it will work.
Why does it work on one side and not the other?
RE: Extrude to surface with draft issue.
Try creating the boss features [u]before[/b] creating the fillet around the body.
Does a Mirror of the lower features work?
I might just revolve the bosses then cut out the inside.
Damn glitches.
