Lofted Flange bend angle
I have a sheet metal cover panel that is constructed as a lofted flange.  It has several square to round transitions.  I flatten the part with the triangulation option turned on to create the bend centerlines.  In draft I would like to know what the bend angle is on the center lines that it creates.  I have tried using the property text both %BN and %BA but it generates a 0 degree angle for every bend.  Does SE export bend angle data for flattened lofted flanges?  If so how can I access?
Jef
V19
Sheet metal part
