Protective Relay Info Needed - IJ7 Differential
I'm looking for any available info on some (probably) very old generator diff relays.  These are called out as IJ7 (or IJ-7), but no manufacturer is listed.
I'm thinking these are old GE relays.  I know GE made an IJD differential relay so these may have been a precursor.  They are definitely being used for generator differential.
Based on the age of the facility, these could be quite old (70 years).
Any info would be appreciated.
RE: Protective Relay Info Needed - IJ7 Differential
Did you try GE's Multilin tech help line 800.547.8629 - they also provide assistance on the old stuff.
