SOLIDWORKS - Cut-list Weight
I'm tryig to introduce the weight in a Cut-list, I could do this just assigning the Mass manually on each cut-list part.
I've tried to create a Weight property in the Structural Member sketch and assign value ("SW-Mass@Part1") like I've done in my part templates, but when I create a weldment part and insert that Structural Member in my Weldment I can't get the weight of each cut-list part, (surprise) in the properties of cut-list part appears the Mass of the entire part (all cut-list parts), but there I can select the Mass Value for each part and I obtain a code like ("SW-Mass@@@Cut-List-Item1@Part1"), but I have to do it manually, If I edit the sketch of my Structural Member again and introduce the value ( "SW-Mass@@@Cut-List-Item1@Part1") instead of ("SW-Mass@Part1") and actualize the weldment part, my surprise is that then appears the next code ("SW-Mass@Structural Member1@Part1.SLDPRT") and the evaluated value is wrong.
My question is, which code have I to write (in the sketch of my structural member) If I want to get the correct weight for each cut-list part in a weldment part?.
Thank you.
Quico
Thank you.
Quico
RE: SOLIDWORKS - Cut-list Weight
If there is a way, we have not found it. We manually set property.
SA
Thank You
You lost me CBL.
SA
I interpreted it as meaning that individual weights of the weldment members cannot be listed in the cut-list ... only the first item of the cut-list will be calculated.
However, I just did a quick test using properties assigned to the profile and it returned the total weight of all members for each cut-list item. So now I'm confused.
Thank you!!!
Quico
OKay, so I am back to my original statement.
SA
