Can the dwg file be protected?
Can the dwg file be protected just like the Microsoft xls or doc file? Meaning any attemp to overwrite the file is not possible unless one use "save as" and under different file name.
Thanks!
Thanks!
Best regards,
ct
RE: Can the dwg file be protected?
Permissions are usually handled on an operating system level. People can have read/write/execute rights to files. Moreover, these are divided up among owner, group, and other. So it is possible prevent people from not writing to your dwg file, but read it only. You can add them to a group to allow writing to a certain project dwg. This is useful when working with projects or groups of engineers.
To change the permissions (in windows) right click and change it appropriately. In unix use chmod ugo+rw-x.
Hopes this helps.
mfelzien
"Everybody is ignorant, only on different subjects." — Will Rogers
