Heat treatment of AL
I work as a stress engineer in Aerospace and I periodically choose different types of Al for design engineers to use, along with their associated heat treatments. What I am looking for is either  a good website or a good understanable book that would explain the positive and negative aspect of each heat treatment with the different types of AL.
RE: Heat treatment of AL
ASM can help you out enormously in this.
I use the book "Engineering Data for Aluminum Strustures", from the Aluminum Association, 5th ed, 1986
or
http://www.matweb.com/main.htm
