Any good detail of "Drop Boxes"
Need a detail for a leach feild "drop box" that will be spec out for an application for fields on a steep grade.
I appreciate it.
RE: Any good detail of "Drop Boxes"
Can you give me a hint about what a drop box is?
Dik
Thanks for the help. After investigation, the leach field drop box is very the same thing as a stormsewer manhole in which the invert of the incoming pipe is set higher than the outgoing pipe. Its application is used on side slopes that are steep.
I appreciate the help.
Dik
Dik
