Time stamp on Plots
Time stamp on Plots
Is there a way to print a time stamp on all drawings? We've got a date stamp by putting an annotation in our drawing template sheet formats and inserting the SW-Date Document property. The problem is there is not a similar property for the time.
Is there a way to extract the time with the API or something like that?
Craig Sink
Mechanical Engineer
Force Design, Inc.
www.forcedesign.biz
RE: Time stamp on Plots
Set swApp = CreateObject("SldWorks.Application")
Set DrawingDoc = swApp.ActiveDoc
MyString = Str(Time)
retval = DrawingDoc.DeleteCustomInfo("Time")
retval = DrawingDoc.AddCustomInfo("Time", "Text", Str(Time))
DrawingDoc.EditRebuild
This will update the property to your system time.
SolidWorks 2006 - SP3.0
UG NX3
Pro/Engineer Wildfire 2.0
Inside the print dialog, you will see document options header/footer. Inside the footer, you can add a time field. If you want to get this text to line up with a box in the title block, it may take a little futzing but you can probably do it.
-Shaggy
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.0 on WinXP SP2
SolidWorks 2007 SP2.0 on WinXP SP2
Craig Sink
Mechanical Engineer
Force Design, Inc.
www.forcedesign.biz
We tried that header footer for awhile. When we changed format the text got large for some reason, so we quit. Now we put $PRP:"SW-Short Date" in the lower left corner. Great control and the font size never changes.
Bradley
I found it on the web, but can't find the source anymore... my guess is Oklahoma SolidWorks User Group but their links are dead.
www.paul-flores.com/macros/stamp.zip
SW07 SP2.0
Flores
I just made a macro for this last month here:
http:/
Enjoy
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
Is there any way to call this macro when I print? Probably using the API which I'm not very adept at. Or maybe there's another approach?
Craig Sink
Mechanical Engineer
Force Design, Inc.
www.forcedesign.biz
CODE
Public swApp As Object
Dim retval As Boolean
Dim bret As Boolean
Dim Doc As Object
Sub main()
Dim swApp As Object
Set Doc = swApp.ActiveDoc
' Error handler for no document loaded
If Doc Is Nothing Then MsgBox "No drawing loaded!", vbCritical: End
' Error handler for document not being a drawing
If Doc.GetType = 3 Then
' Assign the current time and date to custom property
retval = Doc.DeleteCustomInfo("Print Time")
retval = Doc.AddCustomInfo("Print Time", "Text", Now)
' Refresh drawing display to show updated time and date
retval = Doc.ForceRebuild3(False)
End If
' Print
bret = Doc.PrintOut2(0, 0, 1, False, 0, 0, False, 0)
End Sub
I was just thinking that you may also wish to add a line to the end that clears the value after printing so if someone does print via another method, it will appear blank on the drawing rather than providing a previously used date. Maybe just add "retval = Doc.DeleteCustomInfo("Print Time")" to the end after the bret line. Handleman, is there a cleaner way do to this?
Matt
Silicon Valley, CA
