Curve Fitting or Modelling: How to choose?(newbie)
I am trying to predict if a large underground water well (artesiam bore) will dry out?
and if it does when?
(The bore is about 50000 liters a day).
I have used Excel but it is too far out.
I think Matlab will be better to do this type of prediction. But I am too new at Matlab to see how to handle this problem.
I have a set of 300 weekly measurements.
Each measurement correspond to the height  of the water in the underground water well.(artesiam bore).
What is my real problem with Matlab?
Am I trying to Curve fit a data and then project it in the future?
or
Am I trying to model this data and try to predict what may happen?
At the moment  I am   not   getting anywhere because I am trying to fit a curve(polynomial) then use that polynomial to predict what will happen next week, next month, next year when I should do some modelling (modeling).
I believe my idea of modelling is not detailed enough.
May be I should use Fast Fourier Transform?
Any help would be appreciated?
When do you use curve fitting, FFT  or modelling?
Guy
