fire retardant wood trusses
I am in the schematic design stage of a small commercial project, and I need a non-combustible roof framing system. I am looking at either fire retardant wood trusses or light gage metal trusses. Does anyone have any experience with relative cost differences between these two system? I've called a few local wood truss suppliers, but none provide the fire treatment. (Perhaps this tells me light gage is the way to go). I'm not too familiar with the wood truss industry, but could the manufacturer not purchase lumber already fire treated, and construct the trusses as usual? Is anyone aware of corrosion issues of plated wood trusses and the fire treatment? Any insight would be appreciated.
RE: fire retardant wood trusses
Some insurance companies have lower contents rates for wood trusses than metal trusses because of the failure mode. As I understand it, a wood failure is more predictable (loss or crossection) than the sudden steel collapse due to temperature. - Allows more predictable fire fighting without danger and more could be saved.
I did not believe it at first, but I was shown insurance quotes by an owner (unsprinkled building).
Dick
Rated roof is not required in our case. IBC 03 Table 601 footnote c allows fire retardant wood roof trusses and girders in Type I and II (non-combustible), although maybe it is not correct terminology to say it is non-combustible. Just got the preliminary cost estimate, it appears the firetreatment added about $4/sq. ft.. I've got no frame of reference to know if that is reasonable. I can't imagine switching from wood to light gage would be anywhere near that. Good point about insurance rates, I'll bring that to the architects attention as well.
Glad to see you saw that in the footnotes. If it is a small commercial building, I wonder why you would want to classify the building as I or II unless the architect has already made that decision, perhaps for insurance purposes.
Don Phillips
http://worthingtonengineering.com
If you're talking about an entire roof area, I'd go lightgage. I'd recommend asking the WTCA. Do a google search for them.. i think the website is something like www.sbcindustry.com
Add to wood cost - fire treating, special connectors, extra shipping if fire treatment is not local.
With the added costs, consider using metal trusses at a greater spacing (4'-0" or 5'-0" o.c.) with a metal deck instead of plywood. Metal trusses might get more competitive.
