Drive isolation transformer
We specify a lot of VFD systems for dynamometer applications.All of them are based on PWM regen front end converters, and transformers are needed for voltage matching. Drive vendors recommend (or supply) drive isolation transformers. Those transformers were developed to handle additional losses caused by current harmonics associated with 6-pulse conversion technology. Since PWM input converters have practically sinusoidal current waveform (K-factor is just not applicable), we try to consider a cost reduction of the system by not paying extra for "drive isolation transformer" and rather use general purpose transformers. The only additional feature we would like to have in general purpose transformers, is electrostatic shield. It is interesting to know an opinion of engineering community: could a general purpose transformer be used for PWM converters instead of drive iso transformer?
RE: Drive isolation transformer
As long as you are meeting your harmonic distortion requirements with a standard transformer and it is adequately sized, I don't see a big problem. Marketing and sales people have given "K-rated" transformers magical properties that they don't really possess.
But you should have your FAQ list ready when the end-users start asking questions.
