Virtual Studio help...
I have a finished assembly drawing and I need to add a logo and some other info that will be screened onto the part. I have been tasked with creating the finished product in Virtual Studio. How would I go about importing the images and text that I need to complete the illustration?
RE: Virtual Studio help...
Virtual Studio is an add-in for SE, and if it is anything like PhotoWorks for SW, you should not need to import anything anywhere. You should just be able to activate the add-in and work on the native file.
cheers
The image is an .eps, if that helps any.
Step 1:
1A)create a part for the sticker, assemble it on the part.
OR
1B)n.a.
Step 2:
2A)edit the sticker part (1A) or the part on which the logo should be mapped. Format/Style/New : create a new face style, name it logo for example and in the texture tab, import your image (cannot be an eps though... you'll have to convert to a standard image format). After the new face style is created. Apply it on the face or partial face (using a sketch and the split face command) by using Format/Part Painter. Go to VS+ and detach material on that part if anything was already applied to it. By refreshing the presentation image (render), you should see your logo appear.
2B)in VS+, create a material. Using the 'Wrapped filetered image' shader, you will be able to import a standard image file. Then save that material in a personnal archive. Finally apply that material on the appropriate part (face only is not possible though...) by dragging the material on the sticker part for example.
HTH,
Fred
Thank you so much!!
What do you consider a standard image format?  I'm a graphic designer and SE and drafting and all of this is so new to me.
bmp, jpg, tiff can always be used. Some other formats are also possible but not eps.
Fred
I'm having issues with creating a new Style (2A).  There is no "texture tab".
Also when I use 2B, the logo is almost like wallpaper...any suggestions on how to control the number of repetions of the logo?
Thank you
for 2A), are you sure you went to the Part environment and created a new face style using the command Style in the Format menu ? The texture tab should be there.
for 2B), there is a scale setting that should help. (if using method 2A, there is also a scale setting in the texture tab)
It's 2A) OR 2B). You have to choose one method or the other.
thank  you for the clarifaction on the location of the texture tab - I had misread your earlier post.  I was trying both methods to see which I prefered.
