Eccentric Loads on Weld Groups
While perusing thru my manual of steel construction-ASD- I came across the Ultimate Strength Method showing me exponential functions for R values. Under what condition is this analysis carried outin light of the fact that when I come across such problem I'll use the more conventional way of calculating weld size based on torsional stresses and polar moment of inertias.
RE: Eccentric Loads on Weld Groups
DaveAtkins
The elastic approach is better suited to hand-written calculations. The assumptions don't really follow the true behavior of the welds but it errs on the conservative side.
If you need to size one weld or a few welds, either method it acceptable. If you have a process or connection that will be replicated many times, you may be able to save the client some money with a less conservative calculation.
Check out weldgroup spreadsheet on www.yakpol.net . It does it both ways, and it's a pretty big difference in capacities calculated by LRFD and ASD.
