Kubota ARX-B 6500 watt generator failure
my generator was running fine under full load when i "inadvertantly" toggled the voltage select switch (i.e. 240v to 120v then back to 240v). the genset output and voltmeter went to zero. the circut breaker did not trip and its continuity is ok. any ideas on what may have gone first (diode, capacitor, voltage reg, or windings) no odor of burning present.
