How to Remove a Part from a 3D Solid Drawing?
This looks like a very easy question but I am really new at using SolidWorks and any help will be appriciated. Assume that we have a 3D solid drawing. How can we remove a part of it through a surface? I mean, if I want to remove from z=2 surface, what should I do?
Can
Can
RE: How to Remove a Part from a 3D Solid Drawing?
Do you mean you want to cut a feature into a face of a part model?
Can
1) Offset a plane 2 units from the Front plane.
Use the Cut With Plane tool to cut-off the unwanted portion.
2) Offset a plane 2 units from the Front plane.
Use the Intersection Curve tool to create a sketch on the Offset Plane.
Cut-Extrude that profile away from the Offset Plane.
3) Create a sketch on the Top Plane.
Create a rectangle which has one line positioned where you need the sphere to be cut and the other lines outside of the sphere.
Cut-Extrude that profile Through All in both directions.
Can
